Błąd ten dotyczy obwodu czujnika ciśnienia klimatyzacji.
Mam opis postępowania przy tym błędzie po angielsku. Do sprawdzenia przewody między czujnikiem a komputerem wtrysku lub sam czujnik do podmiany.
Na załączonym PDF schemat sterowania silnikiem 2,0 dci. Czujnik ciśnienia to 1202 a komputer to 120, wtyczka czarna 48-pinowa.
0101_A3.PDF
  • 3 lata później...
0101_A3.PDF 50 kB · 39 pobrań
Mógłbyś opisać bardziej usterkę?
Albo dać opis?
Edytowane przez Kowal1997
DF0364
HEATING AND AIR CONDITIONING SYSTEM
CC.0: Short circuit to earth
CO.1: Open circuit or short circuit to +12 V
Special notes:
Use bornier Elé. 1681 for all operations on the engine management computer connectors.
Use the Wiring Diagram Technical Note for Mégane II ph2 or Scénic II ph2.
Check the heating and air conditioning circuit (see MR 364 (Mégane II ph2), 370 (Scénic II ph2)
Check the condition of the refrigerant pressure sensor connector (see Wiring Diagram Technical Note,
Mégane II ph2 or Scénic II ph2, component code 1202).
Check the condition of the engine management computer connector (see Wiring Diagram Technical Note,
Mégane II ph2 or Scénic II ph2, component code 120).
If the connector or connectors are faulty and if there is a repair procedure (see Technical Note 6015A, Repairing
electrical wiring, Wiring: Precautions for repair), repair the connector, otherwise replace the wiring.
Disconnect the battery and the injection computer.
Check the insulation and continuity of the following connections:
• 38Y between components 120 and 1202,
• 38X between components 120 and 1202,
• 38U between components 120 and 1202.
If the connection or connections are faulty and if there is a repair method (see Technical Note 6015A, Electrical
wiring repair, Wiring: Precautions for repair), repair the wiring, otherwise replace the wiring.
If the wiring of the particle filter downstream temperature sensor, component code 1288, is present (with or without
the sensor being present), check the electrical insulation in relation to + 12 V between the following connections:
– 3XU between components 120 and 1288,
– 3TG between components 120 and 1288.
If the connection or connections are faulty and there is a repair procedure (see Technical Note 6015A, Electrical
wiring repair, Wiring: Precautions for repair), repair the wiring, otherwise replace it.
If the fault is still present, replace the refrigerant pressure sensor.
  • Zwycięzca 1
  • Prezes zmienił(a) tytuł na Klimatyzacja nie działa
